Svenska
On our web hosting accounts, a temporary domain is normally set up when the account is created. This temporary domain is based on the main domain (the one entered when the account was ordered), and ends with “.hemsida.eu”. This means that if you order an account using exempel.se as main domain, it will have the domain exempel.se.hemsida.eu added automatically from the beginning. It is added as an alias on the account, and can be deleted whenever you want.
This domain can be used to access the content of the web hosting account before the “real” domain has been pointed towards the account.
In the same way as this alias has been created automatically, you yourself may add temporary domains to the account (e.g. if you want to test a website you’ve built on the account before pointing the domain). This is an alternative to pointing a domain locally towards the account.
To add a temporary domain to your account, follow these instructions regarding how to add an addon domain to the web hosting account. Take special care to set the document root to the same path as you’ve chosen for the “real” domain. Remember to end the temporary domain with “.hemsida.eu”.
So if you’ve added the domain domain.com to your account and selected /domains/domain.com as document root for it, you can create domain.com.hemsida.eu and set the same folder as its document root to reach the website located in that folder.
