Svenska
To give your clients the feeling of being your clients, it’s a good idea to apply some branding (customize the looks) of the cPanel accounts they’re granted access to. This guide details how you change the looks of your cPanel account using the branding feature in WHM.
Accessing the branding interface
Before you can customize the branding on your clients’ cPanel accounts, you need to access the settings. To do that, follow these steps:
- Begin by logging on to WHM.
- Use the search function in the menu to the left to find
customizationand click it.
- You will now reach the interface where you can edit the branding for the theme that your clients see via their cPanel accounts.
Logos
To change the logo that is shown in the top left in cPanel, do the following:
- Begin by accessing the branding settings according to the instructions above.
- Click the tab
Logos.
- You will now get to upload logos, one for light background colors and one for dark ones (you can set that color according to the instructions below). You may also add a description to the logos.
- Click
Update Logosonce you’re done.
Colors
To change the color of the leftmost field in cPanel, do this:
- Click the tab
Colors.
- Now you may choose the color for the left panel in cPanel. If you click the field Main Menu Background Color you may either enter a hexadecimal code for the color of your choice, or set a color using the color picker that pops up.
- Click
Update Colorsonce you’re done.
Favicon
You can set the favicon (the icon shown on the tab in a web browser) if you don’t want the default one. To set your own favicon, follow these instructions:
- Click the tab
Favicon.
- You may now upload the new favicon.
- Click
Update Faviconwhen you’ve selected the file.
Links
To direct your customers to the right contact paths and/or support home pages, you can adjust the links presented for this inside cPanel. Here we describe how:
- Click the tab
Links.
- Edit the links here to match the data you want a cPanel user to end up with.
- Click
Update Linkswhen you’re done.
Contact information
You can also add your contact details directly to the theme used by cPanel accounts on your service, so your customers can easily get in touch with you. Follow these instructions to customize this information:
- Click the tab
Public Contact.
- Please enter your company name (or equivalent) and a link to your website. Keep in mind that this information will be publicly available on all domains used on cPanel accounts associated with your service.
- Click
Saveonce you’re done editing.
Changing theme
If you are not already using the Jupiter theme on your customers’ cPanel accounts, you will need to change the package(s) used to apply Jupiter. We generally describe how to edit a package in this guide (section “Editing an existing package”). The only thing you need to change is the particular theme used:
Click Save Changes by the bottom of the page when you’re done.
