Svenska
If you want the mail for an email address to be forwarded to another email address, you can set this up via the Forwarders feature in cPanel or in the webmail. (This feature is sometimes called alias, mail alias or similar).
Via cPanel
- Click
Forwardersunder theEmailsection.
- You will now have the option to add forwarders, either individually or for entire domains, we will go through both below.
Regular forwarder
- Click
Add Forwarder.
- On this page you need to fill in the email address you want to forward from and to which email address everything should be forwarded. In the
Address to forwardfield, only type the part of the address before @, then select the domain at the bottom. In theForward to email addressfield, type the email address you want to forward the email to.
- Under
Advanced Optionsyou will find some more settings, e.g. you can forward the mail to your default account or pipe it to an application, or simply delete the mail without returning any error message. You don’t need to touch these options unless you know that one of these functions is what you want to use.
- Once you are happy with the settings you have chosen, you can create the forwarding via the
Add Forwarderbutton at the bottom of the form.
Domain forwarder
Domain forwarders forward incoming email to the corresponding email address on the domain you have chosen as a target, so for example email to example.se is forwarded to the corresponding address on example2.se.
- Click
Add Domain Forwarder.
- Select the domain from the drop-down menu (1), enter the domain to which the mail is to be forwarded in the corresponding field (2). Then press the
Add Domain Forwarderbutton (3).
Via the webmail
- Start by logging in to the webmail by going to yourdomain.se/webmail. Replace yourdomain.se with the domain name that comes after @ in your email address.
- Then you can follow the instructions from step 2 onwards in the
Via cPanel->Regular Forwardersection above as it looks exactly the same.
