Svenska
To create a redirect you need to log on to cPanel, we have a guide here that shows you how to do that. Then follow the steps below to create a redirect.
- Click the icon
RedirectsunderDomains.
- You will now see the following:
- Under
Type, you need to choose what kind of redirect it should be. The most common is 301 which is a permanent redirect, this means that you don’t plan to remove the redirect in a while. If you are only going to use the redirect for a short while, you can choose 302 temporary. - In the next field, you need to choose which domain you want to redirect from. In our example, we have chosen oderland-demo.se.
- In the field below it, select whether it is a subpage of the domain you just selected that should be redirected. For example, if you want oderland-demo.se/test to be redirected, type test in that field. If you only want test.se to be redirected, leave that field blank, as in this case.
- In the
Redirect tofield, enter the URL you want the redirection to go to. You must enter http:// or https:// at the beginning, in this example we enter https://my-redirect-target.com. - Under
www. redirection, select whether you want the redirection to redirect with www, only without www or both with and without. - Finally, you can tick whether or not you want to redirect with wildcards. This means that if you go to the address oderland-demo.se/test, for example, you will be redirected to my-redirect-target.com/test. This means that if you redirect with wildcards, you will be redirected to the same subpage on the receiving domain.
- Click
Addwhen you’re done.
