Svenska
Sometimes you need to adjust the resources on your Managed Server. Perhaps you’ve outgrown the current setup and need more power, or you’ve scaled down your business and want something less. Upgrading/downgrading your server this way is no problem, and this guide will walk you through the process.
To upgrade/downgrade your Managed Server, you need to log on to the Client area. Once there, you can order upgrades/downgrades by following these instructions:
- Click
Managed ServerunderServicesin the menu to the left.
- Then click
Viewto the right of the Managed Server you want to upgrade/downgrade.
- Finally, click the tab
Management actionsandUpgrade options.
- Now, make selections what resources you wish to modify, and once you’re done – click
Click to continue.
Once your order reaches us, a technician will get in touch with you and choose an appropriate time for reboot of the server to incorporate the new server resources.
