Svenska
Domain transfer
To transfer a domain name to us, you need to find its EPP code (also known as AUTH-id, authorization code, transfer token etc). You can get this code from your current registrar. Once you have gotten the EPP code, you may begin the transfer.
- Go to this page and enter your domain you want to transfer. Click the Transfer button next to the domain among the search results and enter the EPP code for the domain. Then click the
Confirmbutton.
- The domain is now added to your cart. Unless you want to register or transfer additional domains, scroll down on the page and click
Continue.
- You’ll now get to register as a new client, or log in if you’re a client since earlier. If you’re already logged on to the Client area, please check that you’re logged on to the correct account.
- Check the order summary, choose a payment method (if the domain transfer costs anything), accept our terms and conditions, and click
Complete Your Order.
Failed domain transfer
If a domain transfer fails, you will receive an email message regarding this. In the email, you’ll have a link taking you directly to the right place on our Client area where you can enter the new code. You can also click your way to the page via our Client area. Log in and click Domains under Services in the menu to the left.
You now reach the management page for domains managed with us. Click on All Domains at the top to see all your domain names.
Now, click View to the right of the domain.
Once you’ve reaced the administration page for the domain, you’ll see an information box regarding the failed transfer. Click Complete Domain Transfer.
Then click the Update EPP Code button and enter the correct EPP code.
If the new code works, you’ll get a confirmation email regarding commenced and/or completed domain transfer. Keep in mind that different TLDs require different amounts of time for the transfer.
